Pressure Vessel Wall Thickness with Internal Pressure Applied Calculator
This calculator determines the thickness of a circumferential shell with an internal pressure applied: Typical applications are propane tanks, compressed air storage tanks etc.
The "Joint Efficiency" reflects your confidence in the welded seam areas of the as-manufactured pressure vessel.
