Short Rectangular Membrane Stress and Deflection Calculator
Flat Plates Stress, Deflection Design Equations and Calculators
Short Rectangular Membrane Stress and Deflection Design Calculator and Equations
Figure 1 shows a short rectangular membrane (a / b < 5 ) clamped on four sides under a uniform pressure p.
Preview: Short Rectangular Membrane Stress and Deflection Design Calculator
The deflection at the center of this membrane given by
where n1 is given in figure 1
The stress at various locations on short rectangular membranes are given by following equations for which the values of the coefficients n2 through n7 are given in figure 2.
Center of plate ( c = b / 2, y = a / 2 )
Eq. 3
Center of short side (x = b / 2, y = 0
Eq. 4
Eq. 5
Center of long side ( x = 0, y = a / 2 )
Eq. 6
Eq. 7
It should be noted that the maximum membrane stress at the center of the long side of the plate
Figure 1, Short Rectangular Membrane Clamped on Four Sides
Where
p = pressure
fmax = calculated stress
E = modulus of elasticity
a = length
b = width
t = thickness of membrane
δ = deflection
µ = poisson's ratio
(Premium membership require to view)
- Bell Helicopter Structural Design Manual, 1977
- Long Rectangular Membrane Design Calculator and Equations
- Circular Membrane Stress and Deflection Calculator and Equations
- Circular Plate Concentrated Load Edges Fixed Support Equation and Calculator Circular Plate Concentrated Load Edges fixed Supported Equation and Calculator
- Circular Plate Concentrated Load Floating Equation and Calculator Circular Plate Concentrated Load Floating Equation and Calculator
- Circular plate, uniform load, edges clamped equation and calculator Circular flat plates subject to concentrated or distributed loads (pressure) with the edge either clamped or supported.
- Circular plate, uniform load, edges simply supported equation and calculator Maximum stress and deflection for circular flat plates subject to concentrated or distributed loads (pressure) with the edge either clamped or supported.
- Concentrated load at center of Plate, clamped edges (empirical) equation and calculator
- Rectangular plate, concentrated load at center, simply supported (empirical) equation and calculator
- Bending of Circular Sandwich Plate by Load Applied Through an Insert
- Design Thickness of Pipe Blanks Caps Formula and Calculator per. ASME B31.5
- Regular polygonal plate; all edges simply supported with uniform loading over entire plate Stress and Deflection Equation and Calculator . Per. Roarks Formulas for Stress and Strain
- Regular polygonal plate; all edges fixed with uniform loading over entire plate Stress and Deflection Equation and Calculator . Per. Roarks Formulas for Stress and Strain
- Continuous Plate Supported on an Elastic Foundation of Modulus k (lb/in 2 /in) Stress and Deflection Equation and Calculator . Uniform loading over a small circle of radius r o , adjacent to edge but remote from corner. Per. Roarks Formulas for Stress and Strain
- Combined Stress Circular Cantilever Beam in Direct Compression and Beam Deflection Calculator
- Combined Stress Circular Cantilever Beam in Direct Tension and Stress Deflection Calculator
- Combined Rectangular Cantilever Beam in Direct Compression Equations and Beam Deflection Calculator
- Combined Rectangular Cantilever Beam in Direct Tension and Deflection Equations and Calculator
- Combined Loading on Circular Beam or Shaft in Direct Compression and Deflection Equation and Calculator
- Combined Loading on Circular Beam or Shaft in Direct Tension and Deflection Equation and Calculator
- Combined Loading on Rectangular Beam or Shaft in Direct Compression and Deflection Equation and Calculator
- Combined Loading on Rectangular Beam or Shaft in Direct Tension and Deflection Equation and Calculator
- Combined Loading on Circular Shaft in Direct Compression and Torsion Equation and Deflection Calculator
