Single Dissimilar Materials Lap Joint Equations and Calculator
Fastener, Bolt and Screw Design Torque and Force Calculations
Single Lap Joint with Dissimilar Materials Loads Calculator and EquationsIf the joint is a single lap joint as shown below and are subjected to temperature changes, the equation for the loads in the materials as as follows:
Preview Single Lap Joint with Dissimilar Materials Loads Calculator
Figure 1, Single Lap Joint
Where
A1 = Section area of plate 1
A2 = Section area of plate 2
L = length
g1 = gap plate 1
g2 = gap plate 2
E = modulus of elasticity
T0 = Initial temperature
T2 = final temperature plate 1
T = final temperature plate 2
α1 = Coefficient of thermal expansion plate 1
α2 = Coefficient of thermal expansion plate 2
P = load
- Bell Helicopter Structural Design Manual, 1977
- Plate Joints with Dissimilar Materials Loads Calculator and Equations
- Fastener Relation Between Torque, Thread Pitch and Clamping Force Formula and Calculator
- Fastener Relation Between Bolt Torque and Clamping Force Formula and Calculator per. JIS B 1083
- Bolt Elongation Equation and Calculator while under Axial Stress
- Fastener / Thread Tensile Area of External Thread Formula
- Fastener / Threaded Pitch Circle Diameter Formula and Calculation
- Fastener / Threaded Shear Area Formula and Calculation
- Bolt Elongation Stress Formulas and Calculator per. MIL-HDBH-60 Micrometer Bolt Elongation Method: Below the proportional limit. bolt elongation is directly proportional to axial stress, i.e., elongation increases in the same proportion as stress increases.
- Bolt Fastener Preload Torsion Load Stress Formulas and Calculator per. MIL-HDBH-60
- Bolt Elongation by Turn Formulas and Calculator per. MIL-HDBH-60
- Bolt Torque on Assembly for Gasket Contact Stress per. ASME PCC-1 Equations and Calculator
- Force Required to Strip the Bolt Threads Any Length Formula and Calculator
- Force Required to Strip the Bolt Threads Formula and Calculator
- Torque Clamp Force Calculator
- Stud Preload Calculator
- Bolt Preload Tension Equation and Calculator
- Bolt Preload Tension Force Calculator
- Torque vs Tension Bolts Table Chart SAE J429 Bolts
- Bolt Multiple Diameters Change of Length Under Axial Force Formula and Calculator
