Sleeve Shaft Coupling Design Equations and Calculator
Sleeve Shaft Coupling Design Equations and Calculator.
Torque Capacity of Shaft T = π D3 τ / 16
Torque Capacity of Key T = ( D b L τ ) / 2
Power Capacity of Shaft P = π2 N D3 b τ / 8
Torque capacity of sleeve T = π τ ( Do4 - D4 ) / ( 16 Do)
An allowance should be made for keyway)
For equal strength of sleeve and shaft Do = 1.22 D
Symbols used:
D = Shaft diameter (m)
Do= Sleeve outer diameter (m)
T = Torque capacity (N-m)
b = Width of key (m)
L = Length of key (m)
P = Power transmitted (watt or in SI base units kg-m2-s-3)
N = Shaft speed (rpm)
τ = Allowable shear stress (Pa)
Mechanical Engineers Databook, Carvil
