Solid Circular Segmental Section Torsional Deformation Stress Equation and Calculator
Torsional Deformation and Stress Circular Segmental Section Equations and Calculator Equations and Calculator.
Preview
Torsional Deformation and Stress Solid Circular Segmental Section Calculator
h = r ( 1 - cosα)
K = 2Cr4 where C varies with h/r as follows:
For 0 ≤ h/r ≤ 1.0
C = 0.7854 - 0.0333 (h/r) - 2.6183 (h/r)2 + 4.1595 (h/r)3 - 3.0769 (h/r)4 + 0.9299 (h/r)5
θ = ( T L ) / ( K G )
Shear Stress
For 0 ≤ h/r ≤ 1.0
B = 0.6366 + 1.7598 (h/r) - 5.4897 (h/r)2 + 14.062 (h/r)3 - 14.510 (h/r)4 + 6.434 (h/r)5
τmax = TB / r3 where B varies with h / r
θ = angle of twist (radians)
α = degrees
T = Twisting or torque moment force-length, (in-lbs, N-mm)
L = Length (in, mm)
r = Radius (in, mm)
τ = Unit shear stress force / area (lbs/in2, N/mm2)
G = Modulus of rigidity force / area (lbs/in2, N/mm2)
