Solid Substances Thermal Conductivities
Thermal Conductivities of Miscellaneous Solid Substances *
- Values of k are to be regarded as rough average values for the temperature range indicated
- Woods, oven dry, across grain†
* The thermal conductivity of different materials varies greatly. For metals and alloys k is high, while for certain insulating materials, such as glass wool, cork, and kapok, it is very low. In general, k varies with the temperature, but in the case of metals, the variation is relatively small. With most other substances, k increases with rising temperatures, but in the case of many crystalline materials, the reverse is true.
† With heat flow parallel to the grain, k may be 2 to 3 times that with heat flow perpendicular to the grain, the values for wool are taken chiefly from J. D. MacLean, Trans. ASHRAE, 47, 1941, p. 323
Conversion Factor
Quantity | Reference Unit | is equal to | Conversion Factor | Unit |
1 | BTU (int)/hour-foot-°F | = | 12 | BTU (int)-inch/hour-square foot-°F |
= | 1 | BTU (int)/hour-foot-°F | ||
= | 12.008030593291 | BTU (thermochem)-inch/hour-sq. foot-°F | ||
= | 1.0006692161076 | BTU (thermochem)/hour-foot-°F | ||
= | 0.0041337887321376 | calorie (int)/second-centimeter-°C | ||
= | 0.0041365551299507 | calorie (thermochem)/second-cm-°C | ||
= | 0.0017307346663714 | kilowatt/meter-K | ||
= | 0.017307346663714 | watt/centimeter-°C | ||
= | 1.7307346663714 | watt/meter-K |
Marks Standard Handbook for Mechanical Engineers
- Thermal Conductivities Liquids and Gases
- Thermal Conductivity Theory , Properties, and Applications
- Thermal Conductivity of Refractory Materials
- Thermal Conductivities of Metals
- Thermal Properties of Non-Metals
- Steady State Conduction Multilayer Isothermal Walls Calculation
- Insulation Material Thermal Conductivity Chart
- Coefficients Linear Thermal Expansion
- Heat Loss Insulated Pipe Equation and Calculator
- Thermal Conductivity of Liquids
- Thermal Conductivity Propylene Glycol
- Heat Conduction Wall Equations and Calculator
- Thermal Conductivity Antifreeze Ethylene Glycol
- Thermal Properties of Metals, Conductivity, Thermal Expansion, Specific Heat
- Solid with Spherical Inclusions Effective Thermal Conductivity Equation and Calculator
- Thermal Conductivity of Common Metals
- Thermal Conductivity Conversions Calculator
- Thermal Conductivity, Heat Transfer
- Thermal Conductivity Solid Calculator and Equation
- Effective Thermal Conductivity Formula and Calculator
- Thermal Conductivity Rocks and Soil
