Solid Triangular Section Deformation and Stress Torsional Deformation Stress Equation and Calculator
Torsional Deformation and Stress Solid Triangular Section Equations and Calculator
Preview Torsional Deformation and Stress Solid Triangular Section Calculator
θ = T L / K G
Polar Moment of Inertia
Unit shear stress force
at the midpoint of each side
θ - angle of twist (radians)
T = Twisting or torque moment force-length, (in-lbs, N-mm)
L = Length (in, mm)
a = Distance as indicated (in, mm)
τ = Unit shear stress force / area (lbs/in2, N/mm2)
G = Modulus of rigidity force / area (lbs/in2, N/mm2)
