Specific Heat and Temperature of Mixtures Calculator
Specific Heat and Temperature of Mixtures Equations and Calculator
When substances are mixed the specific heat and temperature of the substances reach an equilibrium on temperature and Specific Heat.
Calculator requires a Preimum Membership
If w1 lb of a substance at temperature t1 and with specific heat c1 is mixed with w2 lb of a second substance at temperature t2 and with specific heat c2 , provided chemical reaction, heat evolution, or heat absorption does not occur, the specific heat of the mixture is
and the temperature of the mixture is
In general,
Eq. 3
To raise the temperature of w1 lb of a substance having a specific heat c1 from t1 to tm, the weight w2 of a second substance required is
Eq. 4
Marks Standard Handbook for Mechanical Engineers
- Specific Heats of Various Gases
- Specific Heat Common Gases
- Specific Heat of Aqueous Solutions of Propylene Glycol
- Pressure - Specific Volume (P-v) Diagram
- Specific Heat Capacity Table at Room Temperature Specific heat capacity c is the change in heat (energy) of a unit mass of material for a unit change of temperature in Btu/lb·°F or Btu/(lbm-°R)
- Thermal Conductivity of Aqueous Solutions of Antifreeze Ethylene Glycol
- Thermodynamic Functions, Typical Symbols and Units
- Thermodynamic Properties of Saturated Water Tables , Specific Volume, Internal Energy for Temperatures 0.01- 190 °C
- Thermodynamic Properties of Saturated Water Tables , Enthalpy, kJ/kg, Entropy, kJ/kg- K for Temperatures 0.01- 190 °C
- Thermodynamic Properties of Saturated Water Tables , Specific Volume, Internal Energy for temperatures between 195 - 374.1 °C
- Thermodynamic Properties of Saturated Water Tables, Enthalpy, Entropy for temperatures between 195 - 374.1 °C
- Thermodynamic Properties of Saturated Water Entry Tables , Specific Volume and Internal Energy for Pressure between 0.6113 - 800 kPa, and Temperatures between 0.01 - 170.43 °C
- Superheated Nitrogen Thermodynamic Properties Table , Specific Volume, m 3 /kg, Internal Energy, kJ/kg, Enthalpy, kJ/kg, and Entropy, kJ/kg-K at pressure 400 kPa, 600 kPas, 800 kPa, and 1000 kPa.
- Superheated Nitrogen Thermodynamic Properties Table, Specific Volume, m 3 /kg, Internal Energy, kJ/kg, Enthalpy, kJ/kg, and Entropy, kJ/kg-K at pressure 1500 kPa, 2000 kPas, 3000 kPa, and 10000 kPa.
- Saturated Methane Thermodynamic Properties Table, Specific Volume, m 3 /kg, and Internal Energy, kJ/kg .
- Freezing Point and Properties of Foods The following is the Unfrozen Composition Data, Initial Freezing Point, and Specific Heats of Foods
- Properties of Water , Specific Heat of Water , Thermal Conductivity of Water, Viscosity of Water
- Specific Internal Energy
- Specific P-V Energy
- Specific Enthalpy
- Ideal-Gas Properties of Air (English Units), Standard Entropy at 1 atm = 101.325 kPa = 14.696 lbf/in. 2
- Ideal Gas Properties of Nitrogen, Diatomic (English Units), Entropies at 1 atm Pressure
- Ideal Gas Properties of Nitrogen, Monatomic (English Units), Entropies at 1 atm Pressure
- Ideal Gas Properties of Oxygen, Diatomic (English Units), Entropies at 0.1 MPa (1 Bar) Pressure, Mole Basis
- Ideal Gas Properties of Oxygen, Monatomic (English Units), Entropies at 0.1 MPa (1 Bar) Pressure, Mole Basis
- Ideal Gas Properties of Carbon Dioxide (SI Units), Entropies at 0.1 MPa (1 Bar) Pressure, Mole Basis
- Ideal Gas Properties of Carbon Monoxide (SI Units) , Entropies at 0.1 MPa (1 Bar) Pressure, Mole Basis
- Specific Volume
- Density
- Energy and Power Equivalences
- Properties of the atmosphere at high altitude
- Properties of air at 1 atm pressure
