Specific Heat Ratio for Liquids and Gases
Specific Heat Ratio γ for Liquids and Gases at Atmospheric Pressure
In thermal physics and thermodynamics, the heat capacity ratio, also known as the adiabatic index, the ratio of specific heats, or Laplace's coefficient, is the ratio of the heat capacity at constant pressure (cp) to heat capacity at constant volume (cv).
Sources:
Marks Standard Handbook of Mechanical Engineers
- Specific Heat of Liquids and Gases
- Specific Heat and Temperature of Mixtures Calculator
- Specific Heat Capacity Table at Room Temperature
- Properties of Pure Substances , Phase Changes Class 5
- Thermodynamics of Multiphase Closed Systems, Class 6
- Steady Flow Gas Power Cycles, Brayton Cycle, Class 11
- Steady Flow Vapor Power Cycles, Rankine Cycle Class, 12
- Steady Flow Vapor Power Cycle, Rankine Cycle with Open Feedwater Heating Class, 13
- Steady Flow Vapor-Compression Refrigeration Cycle, Class 14
- Psychrometric Analysis and Air Conditioning, Class 15
- Saturated and Superheated Vapors
- Constant Pressure Heat Addition
- Properties of the atmosphere at high altitude
- Properties of air at 1 atm pressure
- Specific Heats of Various Gases
- Specific Heat Common Gases
- Thermodynamic Properties of Saturated R-410a Tables for Temperatures -°60 to °71.3 C Enthalpy and Entropy .
- Superheated R-410a Thermodynamic Properties Tables for Temperatures -°60 to °71.3 C
- Superheated R-410a Thermodynamic Properties Tables for Pressure 300 kPa, 400 kPa, 500 kPa, and 600 kPa.
- Superheated R-410a Thermodynamic Properties Tables for Pressure 800 kPa, 1000 kPa, 1200 kPa, and 1400 kPa .
- Superheated R-410a Thermodynamic Properties Tables for Pressure 1800 kPa, 2000 kPa, 3000 kPa, and 4000 kPa
- R-134a Thermodynamic Properties Tables for Temperatures -70 °C to 101.2 °C
- Saturated R-134a Thermodynamic Properties Tables Enthalpy, kJ/kb and Entropy, kJ/k-K
- Superheated R-134a Thermodynamic Properties Tables for Pressures 50 kPa, 100 kPa, 150 kPa, and 200 kPa.
- Superheated R-134a Thermodynamic Properties Tables for Pressures 300 kPa, 400 kPa, 500 kPa, and 600 kPa.
- Superheated R-134a Thermodynamic Properties Tables for Pressure s 800 kPa, 1000 kPa, 1200 kPa, and 1400 kPa.
- Critical Point
- Potential Energy
- Kinetic Energy
- Specific Internal Energy
- Specific P-V Energy
- Specific Enthalpy
- Heat Transfer Practical Approach
