Sprocket Pitch Diameter Formulas and Calculator
Gear Design and Selection Application
The sprocket pitch diameter is an imaginary circle through which the chain pin centers move around the sprocket. The pitch diameter is the fundamental design geometry that determines the size shape and form of the sprocket teeth dimensions.
Preview: Sprocket Pitch Diameter Calculator
Sprocket Pitch Circle Diameter Equation
PD = P / sin [ 180° / N ]
PD = Pitch Diameter
P = Chain Pitch in inches
N = Number of teeth on the sprocket
- Precision Sprockets Caliper Diameters per ANSI/ASME B29.1M
- Sprocket Center Distance Equation and Calculator
- Two Gears Sprocket Speed and Gear Ratio Equation and Calculator
- Roller Chains Review - Engineers Edge
- Roller Chain Sprocket Diameters Dimensions per. ANSI/ASME B29.1M
Reference ANSI/ASME B29.1M
