Steel Column Design per. EUROCODE 2 Calculator and Equations
Steel Column Design Calculator and Equations per. EUROCODE 2
EN 1992 Eurocode 2 applies to the design of buildings and other civil engineering works in plain, reinforced and prestressed concrete. It complies with the principles and requirements for the safety and serviceability of structures, the basis of their design and verification that are given in EN 1990: Basis of structural design. EN Eurocode 2 is concerned with the requirements for resistance, serviceability, durability and fire resistance of concrete structures.
Precision:
Input - Insert the axial load, material property, safety factor, effective length coefficient (by selecting the connection type) and lenght of the steel column.
Load and material property | ||
Steel grade | ||
Partial safety factor (γM) | ||
Elastic modulus (E) | GPa | |
Design load (NED) | kN | |
Dimension |
Unbraced height, x axis (Lx) | m | |
Unbraced height, y axis (Ly) | m | |
Connections |
This application Requires Premium Membership to execute calculations
Output - This will analyse the steel column and selects steel section to design it in the table below from the input values in the table above.
Dimension | ||
Serial size | ||
Section area (As) | cm2 | |
Depth (D) | mm | |
Flange width (B) | mm | |
Flange thic. (tf) | mm | |
Web height (d) | mm | |
Web thic. (tw) | mm | |
Radius (r) | mm | |
Radius of gyration x-x | mm | |
Radius of gyration y-y | mm |
Analysis | |||
Section class | Flange | ||
Web | |||
Slenderness ratio | Lamda x | ||
Lamda y | |||
Phi | |||
Reduction factor Xmin | |||
Compression resistance (Nc,Rd) | Plastic resistance | kN | |
Buckling resistance | kN |
Equations used for Steel Column Design Calculator
Alazar Woldeyohannes
Master's program in Structural Engineering in the School of Mechanical, Aerospace and Civil Engineering
University of Manchester
Email available on request
- Reinforced Concrete Flat Slab per. Eurocode 2
- Reinforced Concrete Beam Design per. Eurocode 2
- Slab Punching Shear Calculation Spreadsheet
- ASTM C14 Concrete Sewer Pipe Dimensions and Weights
- ASTM C76 Reinforced Concrete Sewer Pipe Dimensions and Weights
- Concrete Long Term Creep Deflections per. ACI 318 Equations
- Concrete Modulus of Elasticity Equations and Calculator
- Concrete Modulus of Rupture Equations and Calculator
- Concrete Splitting Tensile Strength Test Equations and Calculator
- AASHTO LRFD Bridge Slab Design Calculator Spreadsheet - This spreadsheet was created to aid in the rapid design and/or checking of Bridge Decks or Reinforced Concrete Boxes in accordance with AASHTO 2004 LRFD.
- Bridge Concrete Slab Design Spreadsheet Calculator
- Asphalt and Concrete Pavement Recycling guidance for preparing plans and specifications and for ensuring the quality of recycled bituminous concrete. Premium Membership Required
- Concrete Slab Volume Estimator Calculator Estimate the require concrete volume to fill the width, height and depth given.
- Concrete Footer Volume Estimator Calculator Calculate required concrete volume to fill footing data given.
- Concrete Column Volume Estimator Calculator Estimate the required concrete to fill the quantity, height and diameter of concrete columns.
- Concrete Rectangular Beam Section Analysis Calculator Concrete Rectangular Beam Section Analysis Calculator Beam or One-Way Type Shear per Per ACI 318-05 Code
- Concrete Structural Designers Guide, High Performance Premium Membership Required
- Flexural Strengthening of Reinforced Concrete Beam with FRP Laminates Spreadsheet Calculator
- Nominal Axial Compressive Strength Non-prestressed Concrete Columns per. ACI 318-14 American Concrete Institute (ACI) Formulas and Calculator
- Reinforced Concrete Beam Design per. ACI 318-08 Calculator Spreadsheet
- Analysis and Design of Concrete T-Beams Spreadsheet Calculator
- Circular Mander Concrete Stress-Strain Section Calculator
- Cantilever Concrete Slab Design per IS 456:2000 Spreadsheet Calculator
- Composite Rectangular Beam and Columns Spreadsheet Calculator
- Concrete Anchor Pullout Tension Design Calculator Concrete Anchor subjected to Tension Pullout Force per ACI 318-02.
- Concrete Anchor Group Pullout Tension Design Calculator Concrete Anchor Tension Pullout Force Design Calculator per ACI 318-02.
- Concrete Anchor in Tension and Shear Near Edge Concrete Anchor Tension Pullout Force Design Calculator per ACI 318-02.
- Concrete Anchor Group Tension and Shear Fasteners Near Two Edges Based on ACI 318-02 Calculator Anchor Group Tension and Shear Fasteners Near Two Edges Based on ACI 318-02
- Concrete Anchor Group Tension and Shear Fasteners Near Two Edges Based on ACI 318-02 Calculator Case # 5 Anchor Group Tension and Shear Fasteners Near Two Edges Based on ACI 318-02
- Concrete Column Base Plate Design Base plates are usually used to distribute column loads over a large area.
- Concrete Floor Slabs Design Requirements and Equation Floor slabs on grade should be analyzed for adequate structural live loads.
- Concrete Foundation Anchor Bolts Design and Selection Anchor bolt is used to attach objects or structures to concrete.
- Concrete Pad Foundation Design Spreadsheet Calculator
- Concrete Reinforced Beam Design to BS8110 Calculator
- Concrete Creep, Shrinkage Factors and Tensile Strength Calculation per. BS EN 1992
- Concrete Slab on Grade according to New Zealand Standards Spreadsheet Calculator
- Flat Concrete Slab Design Spreadsheet Calculator per. BS EN 1992-1: 2004
- Flexural Crack Width in Concrete Calculator per. BS EN 1992-1: 2004
- Manual of Concrete Design , ACI
- Retaining Wall Concrete Design Spreadsheet Calculator per. EN 1992-1: 2004
- Rectangular Concrete Beam Section Analysis Beam Torsion and Shear Rectangular Concrete Beam Section Torsion and Shear Per ACI 318-05 Code
- Rectangular Concrete Beam Section Analysis Crack Control - Distribution of Flexural Reinforcing Flexure, Shear, Crack Control, and Inertia for Singly or Doubly Reinforced Sections Per ACI 318-05 Code
- Rectangular Concrete Beam and Slab Section Analysis Crack Control, and Inertia for Singly or Doubly Reinforced Sections Per ACI 318-05 Code
- Rectangular Mander Concrete Stress-Strain Section Calculator
- Reinforced Concrete Analysis and Design for Torsion Spreadsheet Calculator
- Reinforced Concrete Element Design Spreadsheet Calculator per. EN 1992-1: 2004
- Reinforced Concrete Elements Design and Analysis Spreadsheet Calculator
- Reinforced Concrete Handbook, for Engineers, Architects, and Contractors Premium Membership Required to view Document/Book
- Structural Design Criteria for Buildings Criteria for the design of buildings using cast-in-place or precast construction with plain, reinforced, or prestressed concrete.
