Straight Labyrinth Seal Flow Equation and Calculator
Straight Labyrinth Seal using Martin’s Equation and Calculator
Martin's equation is used for compressible flow with straight-through seals
Figure 1 Straight Labyrinth Seal
Preview Straight Labyrinth using Martin’s Equation Calculator
Martin’s equation for mass flow for straight labyrinth seals
where
m = mass flow rate (kg/s)
A = annular clearance area of the seal (m2)
pt0 = upstream total pressure
(Pa)
pn = downstream static pressure
(Pa)
R = characteristic gas
constant (J / kg-K)
Tt0 = upstream total temperature
(K)
n = number of labyrinth fins (-)
The mass flow function, Q, provides a convenient means for comparing the relative performance of different seals. This is defined by
Substitution for the mass flow function Eq. 2 in Eq. 1 gives
Eq. 3
The flow characteristics for a straight labyrinth for compressible flow, using Eq 3 is illustrated in Figure 1.
Figure 1 Labyrinth mass flow function modeled using Eq 3 (R = 287 J/Kg-K)
Peter R. N. Childs
2014
- Orifice Plate Flow Calculations and Design
- Orifice Plate Type Flow Detector Review
- Orifice Submerged in Liquid Discharge Rate Calculator and Equation
- Air Leakage Rates for Typical Home Components
- Mass Flow Rate for Gas Pipeline Blowdown through Hole or Orifice Excel Spreadsheet Calculator
- Gas Compressibility Factor (Gas Deviation Factor)
- Gas Flow Under Laminar Viscous Conditions Equations and Calculator
- Gas Material Balance Equation
- Pitot-Static Tube Velocity of Fluid Flow Measurement Calculator and Equation
- Venturi Flow Equation and Calculator
- Gas Compressibility Factor Spreadsheet Calculator
- General Energy Equation Conservation of energy principle states that energy can be neither created nor destroyed.
- Simplified Bernoulli Equation Steady flow system in which no work is done on or by the fluid, no heat is transferred to or from the fluid, and no change occurs in the internal energy
- Head The term head is used by engineers in reference to pressure.
- Energy Conversions in Fluid Systems Energy Conversions in Fluid Systems Bernoulli's Equation
- Restrictions on the Simplified Bernoulli Equation Restrictions on the Simplified Bernoulli Fluid
- Extended Bernoulli Bernoulli equation can be modified to take into account gains and losses of head.
- Application of Bernoulli's Equation to a Venturi A venturi, may be analyzed using Bernoulli's equation and the continuity equation.
- Fluid Characteristics Chart Table | Fluids Data, Fluids Density | Vapor Pressure | Kinematic Viscosity
- Fluid Characteristics Chart Table #2 | Fluids Data, Fluids Density
