Structural Beams Diagrams Python Application Script
Beam Deflection and Stress Calculators Formulas & Structural Analysis
Beams diagrams for shear, moments, angle, and deflection Python Application Script
This applications is python-based to perform engineering analysis on beams with diagrams for shear, moments, angle, and deflection
Perform engineering analysis on beams with diagrams for shear, moments, angle, and deflection including 3D plots.
NOTE:
Refunds are not awarded after Python files have been downloaded - review your membership agreement for details.
​Units (if utilized) utilized within calculators are either SI or Imperial (some enable both SI and Imperial) and member (you) are responsible for conversions. Ensure that you verify units utilized in excel application meet your requirements before downloading.
Download: Beams Diagrams for Shear, Moments, Angle, and Deflection
Sample Code
E = 207 * 10 ** 6
L = 1.0
CS = CrossSection ( CrossSectionTypes . CIRC , [ .01 ])
B = Beam ( L , E , crossSection = CS )
B . addPointLoad ( 0 , 11 , 45 )
B . addPointLoad ( L / 2 , - 20 , 45 )
B . addPointLoad ( L , 11 , 45 ) B . addDistributedLoad ( 0 , L , - 2 , 45 ) B . addBoundaryCondition ( L / 2 , BoundaryConditionTypes . ANGLE , 0 )
B . addBoundaryCondition ( L , BoundaryConditionTypes . DEFLECTION , 0 )
B . runAnalysis ( outputToFile = True )
Requirements
  • Currently reactions are not solved for...
    • All loads and reactions must be inputted
  • Boundary conditions currently required
    • one angle AND one deflection value
    • OR two deflection parameters
  • Beam weight is not accounted for by default
    • represent it with a distributed load
Python Module Requirements
numpy
matplotlib
# Testing
pytest
Application demos
Simple Cantilever Beam
Cantilever Graphs
Cantilever Graphs
Cantilever Analysis Console Output
[BEAM ANALYSIS] - Running analysis with beam parameters:
[BEAM ANALYSIS] - length: 1.0
[BEAM ANALYSIS] - Young's modulus of material: 2070000
[BEAM ANALYSIS] - Moment of inertia: 4.9087385212340526e-06
[BEAM ANALYSIS] - [SOLVING] - Solved for xy angle constant C1 = 0.0
[BEAM ANALYSIS] - [SOLVING] - Solved for xy deflection constant C2 = 0.0
[BEAM ANALYSIS] - Singularity functions in XY:
10.0 - 20.0<x - 0.5>^0 + 10.0<x - 1.0>^0
10.0<x - 0>^1 - 20.0<x - 0.5>^1 + 10.0<x - 1.0>^1
(10.0 / 2)<x - 0>^2 - (20.0 / 2)<x - 0.5>^2 + (10.0 / 2)<x - 1.0>^2 + 0.0
(10.0 / 6)<x - 0>^3 - (20.0 / 6)<x - 0.5>^3 + (10.0 / 6)<x - 1.0>^3 + 0.0 + 0.0
[BEAM ANALYSIS] - Report in XY:
Max Shear: 10.0 [N]
Max Moment: 4.995 [N-m]
Max Angle: 0.24604 [rad]
Max Deflection: 0.12302 [m]
Cantilever Input Parameters and Loads
# 1. Define Beam Parameters #
# E - Youngs Modulus #
# I - Moment of Inertia I #
# L - Beam Length #
E = 207 * 10**4
L = 1.0
CS = CrossSection(CrossSectionTypes.CIRC, [.05])
B = Beam(L, E, crossSection=CS)
# 2. Add Loads #
# Use theta = 0 to indicate XY plane #
# Use theta = 90 to indicate XZ plane #
# | (90 - XZ plane) #
# \|________ (0 - XY plane) #
B.addPointLoad(0, 10, 0)
B.addPointLoad(L/2, -20, 0)
B.addPointLoad(L, 10, 0)
# 3. Input Boundary Conditions #
# Use the loading angle convention #
# B.addBoundaryCondition(L/2, BoundaryConditionTypes.ANGLE, 0)
B.addBoundaryCondition(0, BoundaryConditionTypes.DEFLECTION, 0)
B.addBoundaryCondition(0, BoundaryConditionTypes.ANGLE, 0.0)
# 4. Run Analysis #
B.runAnalysis()
Fixed-Support Beam
Fixed-Support Graphs
Fixed-Support Analysis Console Output
[BEAM ANALYSIS] - Young's modulus of material: 207000000
[BEAM ANALYSIS] - Moment of inertia: 7.853981633974483e-09
[BEAM ANALYSIS] - [SOLVING] - Solved for xy angle constant C1 = -1.25
[BEAM ANALYSIS] - [SOLVING] - Solved for xz angle constant C1 = -1.25
[BEAM ANALYSIS] - [SOLVING] - Solved for xz deflection constant C2 = 0.0
(10.0 / 2)<x - 0>^2 - (20.0 / 2)<x - 0.5>^2 + (10.0 / 2)<x - 1.0>^2 - 1.25
(10.0 / 6)<x - 0>^3 - (20.0 / 6)<x - 0.5>^3 + (10.0 / 6)<x - 1.0>^3 - 1.25 + 0.0
[BEAM ANALYSIS] - Singularity functions in XZ:
Max Shear: 10.0 [N]
Max Angle: 0.76886 [rad]
Max Deflection: 0.25629 [m]
[BEAM ANALYSIS] - Report in XZ:
Max Shear: 10.0 [N]
Fixed-Support Input Parameters and Loads
# L - Beam Length #
E = 207 * 10**6
L = 1.0
CS = CrossSection(CrossSectionTypes.CIRC, [.01])
# 2. Add Loads #
B.addPointLoad(0, 10, 90)
B.addPointLoad(L/2, -20, 90)
B.addPointLoad(L, 10, 90)
B.addBoundaryCondition(L, BoundaryConditionTypes.DEFLECTION, 0.0)
# 4. Run Analysis #
B.runAnalysis()
Source
Support:
  • Engineers Edge has tested the basic functions and operation of this application using Python 3.11.9 and supporting modules.
  • Supporting Windows application "Visual Studio Code".
  • THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
