Theoretical Minimum Assembly Part Efficiency Calculator
Design for Manufacturing and Assembly
This calculator is used to determine if the optimal number of parts are being used in an assembly. 100% = perfect though eliminating the sub-assembly in the target end item assembly is desirable.
General Rule of Thumb Part Efficiency Goal > 50% or 1 to zero parts.. The minimum theoretical part count can be most always assumed to be equal to the number of required moving parts for functions.
Te = Tmin / Tp * 100
Declarations
Te = Theoretical Part Count Efficiency, %
Tmin = theoretical number of parts (moving =2, static assembly =1)
Tp = Actual number of parts
- Design for Producibility
- Design For Manufacturing Considerations DFM&DFMA and Training
- Six Sigma for Electronics Design and Manufacturing
- Design for Manufacturability and Concurrent Engineering
Credits:
Kelly L. Bramble, ASEM S-GDTP. FAA A&P,
Engineers Edge, LLC
