Time to Drain a Conical Tank Equation and Calculator
Pressure Vessel Engineering
Efflux Time to Drain a Conical Tank Equation and Calculator
The conical tank, with dimensions given in the figure 1, is initially filled with a liquid. The liquid is allowed to drain out by gravity. Viscosity losses are being ignored in formulas and calculator. Efflux time or time to drain is given by.
tefflux = ( 1 / 5 ) · ( zo / z2 )2 · ( 2 · zo/g )0.5
zo = Vertical Coordinate at the Top of the Cone (m)
z2 = Vertical Coordinate just Above the Datum Plane for Potential Energy (m)
g = Gravitational Acceleration (m/s2)
tefflux = Efflux Time (s)
Figure 1
Conical container from
which a fluid is allowed to drain. The quantity r is the radius of the liquid surface face at height z, and r average is the radius of
the cone at some arbitrary height Z.
- Bird, R.B., Stewart, W.E. and Lightfoot, E.N. (2002). Transport Phenomena (Second Ed.). John Wiley & Sons, Chapter: 7, Page: 229.
- Spherical Tank Draining Time Formulas and Calculator
- Horizontal Tank Draining Time Formulas and Calculator
- Vertical Tank Draining Time Formulas and Calculator
- Hooghoudt's Drainage Rate Equation and Calculator
- Blowdown Time in Unsteady Gas Flow Calculator and Equation
- Orifice Submerged in Liquid Discharge Rate Calculator and Equation
- Fluid Flow Discharge Time under Falling Head Formula and Calculator
- Hydrostatic Discharge of Liquid From Vessel Bottom Equations and Calculator
- Hydrostatic Discharge of Liquid From Vessel Side / Lateral Equations and Calculator
- Head loss in a Pipe Calculator Head loss in a Pipe (Darcy - Weisback Equation)
- Storm Drain Pipe Size Requirement Formula and Calculator
- Rainfall Runoff Rate Formulas and Calculator
