Tolerance JIS B 0401 Table Calculator
Tolerance Table for Regularly Used Fits Excerpt from JIS B 0401 Table Calculator
ISO system of limits and fits Part 1: Bases of tolerances, deviations and fits per. JIS B 0401-1
Hole and Shaft Tolerances range from greater than 0 to 500 mm.
Toggle between holes and shaft tolerances with tab at top of table calculator
Geometrical product specifications (GPS) - ISO code system for tolerances on linear sizes - Part 1: Basis of tolerances, deviations and fits
Japanese Standards Association (JSA)
JSA - JIS B 0401-1
- Drilled Hole Tolerances per MIL-HDBK-727 Design Guidance for Producibilty
- Preferred Force Shrink Fits ANSI B4.1 Calculator
- Formulas for Standard International Tolerance (IT) Grades per.ISO 286-1 1993 and ISO 919-1993
- Table of Hole Bore Tolerances per. ISO 286 Calculator
- Table of Shaft Tolerances per. ISO 286 Calculator
- Class I Fits & Limits Tolerances
- Class II Fits & Limits Tolerances
- Class III Fits & Limits Tolerances
- Class IV Fits & Limits Tolerances
- Class V Fits & Limits Tolerances
- Gage Tolerance Calculator ASME B89.1.5 Pin and Ring Gauges
- Gage Blocks Tolerances Specifications Table JIS B 7506
- Hole Feature Maximum Material Condition MMC vs Feature Size Tolerance Chart Calculator
