Torsional Deformation Stress Eccentric Hollow Circular Equation and Calculator
Torsional Deformation and Stress Eccentric Hollow Circular Section Equations and Calculator.
Preview
Torsional Deformation and Stress Eccentric Hollow Circular Section Calculator
λ = e / D
n = d / D
K = π ( D2 - d2 ) / ( 32 C )
θ = ( T L ) / ( K G )
Shear Stress
θ = angle of twist (radians)
α = degrees
T = Twisting or torque moment force-length, (in-lbs, N-mm)
L = Length (in, mm)
D, d = Diameter (in, mm)
τ = Unit shear stress force / area (lbs/in2, N/mm2)
G = Modulus of rigidity force / area (lbs/in2, N/mm2)
