Torsional Deformation Stress Hollow Thin Elliptical Thin Wall Section Equation and Calculator
Torsional Deformation and Stress Elliptical Hollow thin-walled section of uniform thickness Equations and Calculator. Hollow, thin-walled section of uniform thickness;
U = length of elliptical median boundary, shown dashed:
Preview
Torsional Deformation and Stress Hollow thin-walled section of uniform thickness Section Calculator
θ = ( T L ) / ( K G )
Shear Stress
θ = angle of twist (radians)
α = degrees
T = Twisting or torque moment force-length, (in-lbs, N-mm)
L = Length (in, mm)
a, b = Diameter (in, mm)
t = Thickness wall (in, mm)
τ = Unit shear stress force / area (lbs/in2, N/mm2)
G = Modulus of rigidity force / area (lbs/in2, N/mm2)
