Trapezoid Torque Deformation Stress Equations and Calculator
Torque Applied Deformation and Stress of a Trapezoid Equations and Calculator
Preview
Torque Applied Deformation and Stress of a Trapezoid Calculator
VL = 0.10504 - 0.10s + 0.0848s2 + 0.06746s3 + 0.0515s4
Vs = 0.10504 + 0.10s + 0.0848s2 + 0.06746s3 + 0.0515s4
s = ( m - n ) / b
θ = ( T L ) / ( K G )
Shear Stress Maximum
A = ( m + n) b / 2
θ = angle of twist (radians),
α = degrees,
m, n, b = Length as Indicated (in, mm),
