Uniform Decreasing Loading Flat Plate Stress and Deflection Equation and Calculator
Flat Rectangular Plate; all edges fixed. Uniform Decreasing Loading Parallel to Side b Stress and Deflection Equation and Calculator.
Rectangular Plate; all edges fixed. Uniform Decreasing Loading Parallel to Side b.
Preview: Flat Rectangular Plate all Edges Fixed. Uniform Decreasing Loading Parallel to Side b calculator
Rectangular plate;
all Edges Fixed |
Uniformly decreasing load
parallel to side b |
Stress at x = 0, z = 0
Stress at x = 0, z = 0.4b
and |
Stress at x = 0, z = b
Stress at x = ± a/2, z = 0.45b
Deflection at center:
Symbols used:
q = Total load or force to Plate (lbs/in2)
t = plate thickness, (in)
a = plate length, (in)
b = plate width, (in)
σb = stress, (lbs/in2)
γmax = Deflection (in)
β1,2, 3, 4, 5 = Constant From Table A
α = Constant From Table A
Table A
a/b
0.6
0.8
1.0
1.2
1.4
1.6
1.8 |
2.0
β1
0.1132
0.1778
0.2365
0.2777
0.3004
0.3092
0.3100
0.3068
β2
0.0410
0.0633
0.0869
0.1038
0.1128
0.1255
0.1157
0.1148
β3
0.0637
0.0688
0.0762
0.0715
0.0610
0.0509
0.0415
0.0356
β4
0.0206
0.0497
0.0898
0.1249
0.1482
0.1615
0.1680
0.1709
β5
0.1304
0.1436
0.1686
0.1800
0.1845
0.1874
0.1902
0.1908
α
0.0016
0.0047
0.0074
0.0097
0.0113
0.0126
0.0133
0.0136
