Uniform Loading Adjacent to Corner Stress and Deflection Equation and Calculator
Continuous Plate Supported on an Elastic Foundation of Modulus k (lb/in2/in) Stress and Deflection Equation and Calculator.
Uniform loading over a small circle of radius ro, adjacent to corner.
Preview: Continuous Plate Supported on an Elastic Foundation of Modulus k (lb/in2/in) Stress and Deflection Calculator
adjacent to corner.
Stress Under Load
Stress Under Load
at distance d distance defined from the corner along diagonal
Equation constant
Deflection at the Corner:
Deflection
W = Total load (force) (lbs)
E = Modulus of Elasticity (lb/in2)
Do = Diameter where loading applied (in)
d = Diagonal distance load applied from corner (in)
ro = Radius where loading applied (in)
k = Foundation of Modulus (lb/in2/in)
σa = stress, (lbs/in2)
qo = Maximum Foundation Pressure (lbs/in2)
ymax = Deflection (in)
