Uniformly Heated Rectangular Plate Stress Calculator and Equations
Heat Transfer Engineering
Partially Restraint of a Uniformly Heated Rectangular Plate Stress Calculator and Equations
Uniformly Heated Rectangular Plate Restrained in the X and Y Directions by a Frame Plate Calculator and Equations for Stress
Preview Partially Restrained Rectangle Plate in Frame, Uniformly Heated Stress Calculator
σ x 1 = E 1 / ( 1 μ 2 ) [ ϵ x + μ ϵ y ( 1 + μ ) α 1 ( T 1 T 0 ) ]
σ y 1 = E 1 / ( 1 μ 2 ) [ ϵ y + μ ϵ x ( 1 + μ ) α 1 ( T 1 T 0 ) ]
Eq. 3
σ 2 = E 2 [ ϵ x α 2 ( T 2 T 0 ) ]
Eq. 4
σ 3 = E 3 [ ϵ y α 3 ( T 3 T 0 ) ]
Eq. 5
Σ F x = σ x 1 A x 1 + σ 2 A 2 = 0
Eq. 6
Σ F y = σ y 1 A y 1 + σ 3 A 3 = 0
Eq. 7
A x 1 = b t
Eq. 8
A 2 = 2 w t 2
Eq. 9
A y 1 = a t
Eq. 10
A 3 = 2 v t 3
Equations 5 and 6 can be solved simultaneously for Ex and Ey. Substituting back into equations 1,2,3, and 4, the stress at the edge of the members can be obtained.
Partially Restrained Square Plate
Figure 1 - Partially Restrained Rectangle Plate
Where
E1 = modulus of elasticity plate 1
E2 = modulus of elasticity frame plate 2
E3 = modulus of elasticity frame plate 3
α1 = coefficient of thermal expansion plate 1
α2 = coefficient of expansion frame plate 2
α3 = coefficient of expansion frame plate 3
εx = strain along x coordinate
εy = strain along y coordinate
T0 = reference temperature
T1 = temperature center plate
T2 = temperature frame plate 2
T3 = temperature frame plate 3
µ = Poisson's ratio
σx1 = stress
σx2 = stress
a = width
b = height
w = width of plate frame
v = width of plate frame
t1 = thickness plate 1
t2 = thickness plate 2
t3 = thickness plate 3
  • Bell Helicopter Structural Design Manual, 1977
