Universal Columns Section Properties Calculator
BS EN 10365 Euro Code 3 Universal Columns Section Properties Calculator
The following design data to Eurocode 3 (in accordance with the UK National Annex):
Section properties:
Universal Column Section Properties
BS EN 10365 Euro Code 3 Universal Columns Beams
- Universal Narrow Beams Dimension Data
- Structural Steel AISC Shapes Properties Viewer
- AISC, ASTM Wide Flange #1 Steel
- AISC, ASTM Wide Flange #2 Steel
- AISC, ASTM S Narrow Flange I Beam Steel
- Steel Section Properties Chart Narrow I-Beam BS 4-1 | EN 1993-1-1
- Steel Section Properties Chart Wide I-Beam BS 4-1 | EN 1993-1-1
- Indian Standard Flange Beams per. IS 808
- Properties of Rolled-Steel Shapes I-Beam Sections, Standard GOST 8239-72
