Universal Tees (T) Split from UC Section Calculator
Universal Tees (T) Split from UC per BS EN 10365 Euro Code 3 Section Properties Calculator
UC = Universal Column
The following design data to Eurocode 3 (in accordance with the UK National Annex):
Section properties:
Universal Tee Section Form Universal Column Properties
+ These sections are in addition to the range of sections specified by BS EN 10365
- Indicates that no values of U and X are given, as lateral torsional buckling due to bending about the y-y axis is not possible, because the second moment of area about the z-z axis exceeds the second moment of area about the y-y axis
