Universal Unequal leg Angles (L) Section Properties Calculator
Universal Unequal leg Angles (L) per. BS EN 10365 Euro Code 3 Section Properties Calculator
The following design data to Eurocode 3 (in accordance with the UK National Annex):
Section properties:
Universal Unequal leg angles (L) Section Properties
+ These sections are additional to the range in BS EN 10056-1
cy is the distance from the back of the short leg to the centre of gravity
cz is the distance from the back of the long leg to the centre of gravity
BS EN 10365 Euro Code 3 Universal Unequal leg Angles "L"
- Universal Equal leg Angles L Section Properties Calculator
- Universal Parallel Flange Channels Properties Calculator
- Universal Bearing Piles Section Properties Calculator
- Universal Columns Section Properties Calculator
- Universal Narrow Beams Dimension Data
- Structural Steel AISC Shapes Properties Viewer
- AISC, ASTM Wide Flange #1 Steel
- AISC, ASTM Wide Flange #2 Steel
- AISC, ASTM S Narrow Flange I Beam Steel
- Steel Section Properties Chart Narrow I-Beam BS 4-1 | EN 1993-1-1
- Steel Section Properties Chart Wide I-Beam BS 4-1 | EN 1993-1-1
- Indian Standard Flange Beams per. IS 808
- Properties of Rolled-Steel Shapes I-Beam Sections, Standard GOST 8239-72
