Unwin Gas Change of Pressure and Calculator and Formulas
The Unwin formula has been successfully used in steam piping calculations for many years. It is quite satisfactory for most purposes. However, at high flow rates, the pressure drops predicted by the Unwin formula are found to be higher than actual values.
The Unwin formula in USCS (Imperial) units is as follows:
Equation 1
ΔP = ( 3.625 x 10-8 ) ν L W2 ( 1 + 3.6 / D) / D5
ΔP = pressure drop, psig
W = steam flow rate, lb/h
L = pipe length, ft
D = pipe inside diameter, in
ν = specific volume, ft3/ lb
In SI units, the Unwin formula is as follows:
Equation 2
ΔP = 675.2723 ν L W2 ( 1 + 91.44 / D) / D5
ΔP = pressure drop,
kPa
kg/hr
L = pipe length,
m
D = pipe inside diameter, mm
ν = specific volume, m3/ kg
- Gas Flow Rate Through Orifice Equations and Calculator per. ISO 5167
- Natural Gas Pipe Flow Rate Calculator
- Appliance Gas Pipe Flow Rate Capacities
- Transmission Gas Line Isothermal Flow Equations and Calculator
- Fluids Discharge Measurement Structures and Systems , Basic Principles of Fluid Flow as Applied to Measuring Systems
- Hydraulic and Pneumatic Design and Engineering
- Piping Calculations Manual,
E. Shashi Menon
SYSTEK Technologies, Inc
