Wide Flange Beam with Unequal Flanges per. Roarks Formulas for Stress and Strain Equations and Calculator
Wide Flange Beam with Unequal Flanges Section with Concentrated Intermediate Torque applied Deflection and Stress Equations and Calculator #7 of 1a Loading.
Formulas for the elastic deformations of uniform thin-walled open members under torsional loading.
Per. Roarks Formulas for Stress and Strain - Formulas for torsional properties and stresses in thin-walled open cross sections, Table 10.2.
Wide Flange Uneven Flanges
Section Dimensional Definitions Figure 1
Loading Configuration (Section Shown May not Match Section given in Figure 1)
Left end free to twist and warp, right end free to warp but not twist.
Concentrated intermediate torque of Twin Channel With Flanges Inward Beam
Figure 2
Loading Declarations Image (Section Shown May not Match Section given in Figure 1)
Concentrated intermediate torque of Channel Beam
Concentrated intermediate torque of Twin Channel With Flanges Inward Beam Orientation Declarations Image
Figure 3
Preview: Wide Flange With Unequal Flanges Thin Wall Stress and Torsional properties #7 calculator
Wide Flange Section Properties Constants Formulas See: Figure 1
Constant e
Constant K
Constant Cw
Stress throughout the thickness at corners A and B
throughout the thickness at points A and B if
t2b22 > t1b12
Stress throughout the thickness at corners C and D
throughout the thickness at points C and D if
t2b22 < t1b12
Shear stress due to warping rigidity
Shear Stress
throughout the thickness at a point
midway between A and B
t2b2 > t1b1
Shear Stress
throughout the thickness at a point midway
between C and D if
t2b2 < t1b1
Torsion
at the surface everywhere
Shear stress due to torsional rigidity
Torsional Shear Stress
Left end free to twist and warp, right end free to warp but not twist Formulas:
Angle constants theta
Functiona 1,2,3,4
Functions fa1, fa2, Fa2, etc
Sinh functions
Ca1... functions
Area functions
Point 0 indicates the shear center se "Concentrated intermediate torque of Channel Beam Orientation Declarations image ";
G = modulus of rigidity (shear modulus) of the material (lbs/in2, m2);
θ', θ'', θ''', = are the successive derivatives of y with respect to the distance x;
A, B, C, D, E, F, e, h, b1= Dimensional data Figure 1 (in, m).
Unit step function defined by use of ⟨ ⟩
⟨ x - θ ⟩0
if x < a, ⟨ x - a ⟩n =0;
if x > a, ( x - a) n ;
The function sinh β⟨ x - a ⟩ is defined as zero if x < a
β = ( KG/CwE)1/2
Supplemental selected special cases and maximum values (not included in calculator).
Roarks Formulas for Stress and Strain, 7th Edition, Table 10.2 and 10.3 Formulas for torsional properties and stresses in thin-walled open cross sections.
