Wood Dowel Bearing Strength Calculator
Civil Engineering Application & Design Resources
Beam Deflection and Stress Calculators Formulas & Structural Analysis
Wood Maximum Dowel Bearing Strengths, for Dowel-Type Fasteners in Wood Members
Dowel bearing length in the side member(s) and main member, is best determined based on the length of dowel bearing perpendicular to the application of load. For cross-laminated timber where the direction of loading relative to the grain orientation at the shear plane is parallel to grain, the dowel bearing length in the perpendicular plies shall be reduced by multiplying the bearing length of those plies by the ratio of dowel bearing strength perpendicular to grain to dowel bearing strength parallel to grain.
For Dowels 1/4" ≤ D ≤ 1"
Fe|| = 11,200 G
For Dowels perpendicular
Fep = (6,100 G1.45) / D0.5
Eq. 3
for D < 1/4"
Fe = 16,000 G1.84
Fe|| = Dowel installed parallel to wood grain, lbs/in2
Fep = Dowel installed perpendicular to wood grain, lbs/in2
Fe = Dowel less than 1/4" diameter, lbs/in2
D = dowel diameter, in
G = Specific gravity
National Design Specification for Wood Construction (AWC-NDS)
American Wood Council
- Specific Gravity and Weight of Wood
- Dowel Pin Installation Design Tolerance Table Chart
- Standard Unhardened Ground Dowel Pins per ANSI/ASME B18.8.2
- ISO Metric Dowel Pins per DIN EN ISO 8734
- Machine Dowel Pins Chart ANSI ASME
- Lag Screws in Wood Pullout Resistance Force Formulae and Calculator
- Bolt or Pin In Single Shear Equation and Calculator
- Bolt Single and Double Shear and Tension Stress Analysis Calculator per AISC 9th Edition
- Allowable Loads and Stress in Wood Formulae and Calculator
- Wood Nail Pullout Withdraw Resistance Force Formulae and Calculator
- Pressed Drift Pin Bolts in Wood Force Formulae and Calculator
- Density of Wood Equation and Calculator
- Pilot Holes for American Wood Screws
- Commercial Lumber Sizes Chart Table
