Z-Section Flange Beam Intermediate Torsional Loading Equations and Calculator
Z-Section Flange Beam with Concentrated Intermediate Torsional Loading Applied Deflection and Stress Equations and Calculator #8 of 1a Loading.
Formulas for the elastic deformations of uniform thin-walled open members under torsional loading.
Per. Roarks Formulas for Stress and Strain - Formulas for torsional properties and stresses in thin-walled open cross sections, Table 10.2.
Section Dimensional Definitions Figure 1
Loading Configuration (Section Shown May not Match Section given in Figure 1)
Left end free to twist and warp, right end free to warp but not twist.
Concentrated intermediate torque of Twin Channel With Flanges Inward Beam
Figure 2
Loading Declarations Image (Section Shown May not Match Section given in Figure 1)
Concentrated intermediate torque of Twin Channel With Flanges Inward Beam Orientation Declarations Image
Figure 3
Preview: Z-Section Beam Thin Wall Stress and Torsional properties #8 calculator
Z-Section Properties Constants Formulas See: Figure 1
throughout the thickness at points A and D |
Shear stress due to warping rigidity |
throughout the thickness at a distance |
Shear stress due to torsional rigidity
Left end free to twist and warp, right end free to warp but not twist Formulas:
Point 0 indicates the shear center se "Concentrated intermediate torque of Channel Beam Orientation Declarations image ";
G = modulus of rigidity (shear modulus) of the material (lbs/in2, m2);
θ', θ'', θ''', = are the successive derivatives of y with respect to the distance x;
A, B, C, D, E, F, e, h, b1= Dimensional data Figure 1 (in, m).
Unit step function defined by use of 〈 〉
〈 x - θ 〉0
if x < a, 〈 x - a 〉n =0;
if x > a, ( x - a) n ;
The function sinh β
β = ( KG/CwE)1/2
Roarks Formulas for Stress and Strain, 7th Edition, Table 10.2 and 10.3 Formulas for torsional properties and stresses in thin-walled open cross sections.
