ASTM Structural Shape C - Channel Aluminum ASTM B 221 for Aluminum 6061-T6 Typical Size Table Chart
Structural Materials Menu
Aluminum Association Standard Channels Dimensions, Areas, Weights and Section Properties - Material ASTM B 308 ASTM International - Materia Specification ASTM B308/B308M-20 - Standard Specification for Aluminum-Alloy 6061-T6 Standard Structural Profiles. Dimensional data given in inches. Industry does provide custom extruded sizes.
For sizes 2" to 12"
AISC Structural Shape C - Channel
AISC Structural Shape C - Channel, Standard Aluminum
All dimensional data given in inches
Size
d x bf
Web Thickness (tw) Flange Thickness (tf) Weight (lb/Ft) Area (in2)
2.00 x 1 .130 .243 .580 .490
2.00 x 1 1/4 .170 .273 1.070 .910
3.00 x 1.41 .170 .273 1.420 1.210
3.00 x 1.43 .187 .273 1.480 1.260
3.00 x 1.50 .258 .273 1.730 1.470
3.00 x 1.60 .356 .273 2.070 1.760
4.00 x 1.58 .184 .296 1.850 1.590
4.00 x 1.72 .321 .296 2.500 2.130
5.00 x 1.75 .190 .320 2.320 1.970
5.00 x 1.89 .325 .320 3.110 2.640
6.00 x 1.92 .200 .343 2.830 2.400
6.00 x 2.03 .314 .343 3.630 3.090
6.00 x 2.16 .437 .343 4.480 3.830
7.00 x 2.09 .210 .366 3.380 2.870
7.00 x 2.19 .314 .366 4.230 3.600
7.00 x 2.30 .419 .366 4.190 4.330
8.00 x 2.29 .250 .390 4.250 3.380
8.00 x 2.34 .303 .390 4.750 4.040
8.00 x 2.43 .233 .413 4.600 3.940
9.00 x 2.49 .285 .413 5.190 4.410
9.00 x 2.65 .448 .413 6.910 5.880
10.00 x 2.60 .240 .436 5.280 4.490
10.00 x 2.74 .379 .436 6.910 5.880
10.00 x 2.89 .526 .436 8.640 7.350
10.00 x 3.03 .673 .436 10.370 8.820
12.00 x 2.96 .300 .498 7.410 6.300
12.00 x 3.05 .387 .501 8.640 7.350
12.00 x 3.17 .510 .501 10.370 8.820
15.00 x 3.40 .400 .650 11.710 9.960
15.00 x 3.72 .716 .650 17.280 14.700
Tensile Property Limits
Tensile strength, min, ksi [MPa] 38.0 [260]
Yield strength, min, ksi [MPa] 35.0 [240]
Elongation,c min, %
in 2 in. [50 mm] 10 [10]D
in 4D [5D or 5.65 yA ] 10 [9]
c Elongations in 2 in. [50 mm] apply for profiles tested in full section and for sheet-type specimens machined from material up through 0.500 in. [12.5 mm] in thickness having parallel surfaces. Elongations in 4D [5D or 5.65 \/A], where D and A are diameter and cross-sectional area of the specimen, respectively, apply to round test specimens machined from thicknesses over 0.250 in. [6.30 mm].
dFor thicknesses less than 0.250 in. [up through 6.30 mm] the minimum elongation is 8 %.
Reference: Aluminum Association Standard Structural Profiles - 2020
