Design Concrete Slab NZ Standards Spreadsheet Calculator
Civil Engineering Resources
Design of Concrete Slab on Grade according to New Zealand Standards Spreadsheet Calculator
Download:
- Design of Concrete Slab on Grade according to New Zealand Standards Spreadsheet Calculator
This spreadsheet has been designed to accommodate gravity loads which are typically present on industrial floor slabs. Spread sheets are provided for load layouts comprising of- single rows of warehouse racks, rack which are placed back to back, and forklift wheel loads. Other load layouts can be accommodated by manual combination of the stresses associated with individual load points. A spreadsheet is provided for single point loads to assist in this.
Background: The background theory for this excel spreadsheet is covered in the CCANZ publication " Concrete Ground Floors & Pavements for Commercial & Industrial Use Part 2- Specific Design." It is recommended that users of this programme read this document which is obtainable form the Cement and Concrete Association of NZ phone Wellington 04 4998820. An important assumption to note is that the spreadsheet assumes tensile stresses due to restrained shrinkage are negligible.
Preview
- Manual of Concrete Design ACI
- Concrete Foundation Anchor Bolts Design
- Concrete Anchor Tension Pullout and Design Calculator
- Reinforced Concrete Beam Design to BS8110 Calculator
- Reinforced Concrete Beam Design per. ACI 318-08 Calculator Spreadsheet
- Concrete Pad Foundation Design Spreadsheet Calculator
- Concrete Structural Designers Guide
- Reinforced Concrete Handbook
- Concrete Creep Shrinkage Factors and Tensile Strength Calculation
