Rock Engineering Properties
Engineering Properties of Typical Rock Types
Table chart giving typical properties including Solid density, Unconfined Compressive Strength, Young's Modulus, Poisson's Ratio etc.
Material |
Solid Density (t/m3) |
Unconfined Compressive Strength (MPa) |
Young's Modulus (GPa) |
Poisson's Ratio |
Basalt |
3.00 |
78 – 412 |
20 – 100 |
0.14 – 0.25 |
Bauxite |
2.05 |
Clay – dense, wet |
1.70 |
Coal, Anthracite |
1.60 |
8 – 50 |
Coal, Bituminous |
1.36 |
Dolerite |
2.80 |
290 – 500 |
Dolomite |
2.96 |
15 – 118 |
20 – 84 |
0.1 – 0.2 |
Earth, moist |
1.80 |
Gneiss |
2.88 |
78 – 240 |
25 – 60 |
0.1 – 0.19 |
Granite |
2.72 |
100 – 275 |
25 – 70 |
0.15 – 0.34 |
Gypsum |
2.80 |
Iron ore |
4.89 |
Limestone |
2.64 |
10 – 245 |
10 – 80 |
0.1 – 0.23 |
Limonite |
3.76 |
Magnetite |
5.05 |
Marble |
2.48 |
50 – 200 |
60 – 90 |
0.2 – 0.35 |
Mica-Schist |
2.70 |
Porphory |
2.56 |
Quartzite |
2.50 |
85 – 350 |
26 – 100 |
0.15 – 0.2 |
Sandstone |
2.40 |
50 – 160 |
5 – 86 |
0.1 – 0.3 |
Shale |
2.58 |
20 – 150 |
8 – 30 |
0.1 – 0.3 |
Silica Sand |
2.56 |
Siltstone |
2.25 |
Sources:
Blasting and Explosives Quick Reference Guide 2010, Dyno Nobel
- Stream Power Formulas and Calculator Stream power is a geomorphology concept that is a measure of the available energy a stream has for moving sediment, rock, or woody material.
- Thermal Conductivity of Soils and Rocks
- Soil & Slope Stability Analysis
- Soil Cohesion Values Table Typical soil cohesion values for different soils
- Bearing Capacity of Soils ultimate bearing capacity under a long footing at the surface of a soil is given by Prandtl's equation:
- Bearing Capacity of Soils Analysis and Review Design Document
- Soil Compaction Testing Core Method sand-cone method is used to determine in the field the density of compacted soils in earth
- Soil Permeability Review The coefficient of permeability k is a measure of the rate of flow of water through saturated soil under a given hydraulic gradient
- Soil Settlement Under Foundations For the purpose of wind or earthquake engineering, columns may be designed to resist lateral forces.
- Soil, Stress Conditions Analysis Stress conditions in soils at a point, stresses beneath structures and embankments
- Soils and Foundations, Reference Manual Vol. I
- Soils and Foundations Reference Manual Vol. II Naresh C. Samtani*, PE, PhD, Edward A. Nowatzki*, PE, PhD
