ANSI/ASME B18.8.1 Cotter Pin Application Size Table Chart
Cotter Pins per ANSI/ASME B18.8.1
A cotter is a pin or wedge passing through a hole to fix parts tightly together. In British usage cotter pin has the same meaning, but in the U.S. it refers to a different fastener .
Typical applications are in fixing a crank to its crankshaft , as in a bicycle, or a piston rod to a crosshead , as in a steam engine. Note: the angle of the wedge determines the position of the parts being held, therefore on a bicycle the pedal arms will only be at 180 degrees to each other if the angle of the cotter pin's wedge is the same on both pins.
NOMINAL SIZE | A Diameter | C Head Diameter | D Prong Length | LENGTH |
.03125 | 0.032 | 0.060 | 0.010 | 0.125 to 3 by 1/8 |
.046875 | 0.048 | 0.090 | 0.020 | 0.125 to 3 by 1/8 |
.0625 | 0.060 | 0.120 | 0.030 | 0.25 to 3 by 1/8 |
.078125 | 0.076 | 0.160 | 0.040 | 0.25 to 3 by 1/8 |
.09375 | 0.090 | 0.190 | 0.040 | 0.375 to 3 by 1/8 |
.109375 | 0.104 | 0.220 | 0.050 | 0.375 to 3 by 1/8 |
.125 | 0.120 | 0.250 | 0.060 | 0.5 to 3 by 1/8 |
.140625 | 0.134 | 0.280 | 0.060 | 0.5 to 3 by 1/8 |
.15625 | 0.150 | 0.310 | 0.070 | 0.625 to 3 by 1/8 |
