Reinforced Concrete Beam Design per. ACI 318-08 Calculator Spreadsheet
NOTE:
Excel Engineering Calculators
Civil Engineering Design and Engineering
The “Building Code Requirements for Structural Concrete” (“Code”) per. ACI 318-08 covers the materials, design, and construction of structural concrete used in buildings and where applicable in nonbuilding structures. The Code also covers the strength evaluation of existing concrete structures.
Among the subjects covered are: drawings and specifications; inspection; materials; durability requirements; concrete quality, mixing, and placing; formwork; embedded pipes; construction joints; reinforcement details; analysis and design; strength and serviceability; flexural and axial loads; shear and torsion; development and splices of reinforcement; slab systems; walls; footings; precast concrete; composite flexural members; prestressed concrete; shells and folded plate members; strength evaluation of existing structures; provisions for seismic design; structural plain concrete; strut-and-tie modeling
Preview: Reinforced Concrete Beam Design per. ACI 318-08 Excel Calculator Spreadsheet
Download: AASHTO 2004 LRFD Bridge Slab Design Excel Calculator Spreadsheet Per. BS 8110
Reference
AASHTO LRFD
