Assembly Analysis Cost and Efficiency Excel Spreadsheet
NOTE:
Design for Manufacturing and Assembly Resources
Description:
Assembly Process Analysis Procedure and Charting Excel Spreadsheet
  1. The first step is to determine the assembly sequence.
  2. The assembly time for each component part is then obtained by adding the handling time of that part to its insertion time.
  3. Once the components and the assembly time for each are known, total assembly time and assembly cost for the existing design is evaluated.
Download: Assembly Analysis Cost and Efficiency Spreadsheet
