Brittle Failure Theories Computing Safety Factors Excel Spreadsheet Calculator
NOTE:
Download: Brittle Failure Theories Computing Safety Factors Excel Spreadsheet Calculator
Preview: Brittle Failure Theories Computing Safety Factors Excel Spreadsheet Calculator
Variables and Calculated Data:
- Note: the graph of the Distortion Energy plot is an approximation, not an actual function (excel won't plot functions)
- Tensile Strength (Sut)
- Compression Strength (Suc)
- Principle Stresses
- Minimum Safety Factor
- Maximum Normal Stress
- Modified-Mohr
- Coulomb-Mohr
- Brittle Failure Envelopes
- Max. Normal Stress
- Modified Mohr
- Load Line
- Stress Location
