Capacity of Standard Universal Beams According to BS 5950 Spreadsheet Calculator
NOTE:
Structural Engineering and Design Equations and Calculators
Capacity of Standard Universal Beams According to BS5950 Spreadsheet Calculator
Download:
This spreadsheet calculates the capacity of standard universal beams according to BS5950 - 1998.
Simply click on the appropriate worksheet tab at the bottom of the page to determine the strength of a member in either tension, compression or bending.
The Different worksheets perform the following functions:
  • Section Properties
  • Section properties are described and calculated in this spreadsheet.
  • Lateral Torsional Buckling
  • The strength of a member subjected to bending is explained and calculated on this sheet
  • Lateral Buckling
  • The strength of a member subjected to axial forces is explained and calculated on this sheet
  • Tension
  • The strength of a member subjected to tension is explained and calculated on this sheet
  • Combined Actions
Preview:
