Distribution Transformer Calculations Excel Spread Sheet
NOTE:
Download: Distribution Transformer Excel Spread Sheet Calculator
Description:
- Distribution Transformer Calculations – MS nput parameters:
- Primary rated voltage (kV.)
- Secondary rated voltage (kV.)
- Max. demand load (kW)
- Power factor after correction
- Transformer type
- Permissible loading percentage (%)
- The nearest standard transformer rating (KVA)xcel Spreadsheet
