Inverting Op-Amp Gain Table Calculator Excel Spread Sheet
NOTE:
Inverting Op-Amp Gain Table Calculator Excel Spreadsheet
Download: Inverting Op-Amp Gain Table Calculator Excel Spreadsheet
Description:
This sheet shows the gain of an inverting op-amp for standard 5% valued resistors. Read the values of R1 down the left-hand column, and the values of R2 across the top row.
