Power Factor Capacitor Size Design Calculator
NOTE:
Instrumentation, Electronics and Control Sensors
Excel spread calculator calculate the Size of the Bank, Costing period and details for the Design and configuration of the capacitor bank.
Download: Power Factor Capacitor Size Design Calculator
This excel calculator will determine the the following data:
System Voltage
Capacitor Line Voltage
Capacitor Connected in
Capacitor Cost / Kva
Annual Intrest & Depriciation/Capacitor
Enter Electricity Terrif Details:
- Daily Working Hours
- Electricity Charge / Kva
- Electricity Charge / Kw
Then you will get the size of capacitor bank
- Leading KVAR
- Leading KVAR supplied by each Phase
- Capacitor Charging Current (Ic)
- Capacitance of Capacitor
- Required No of Capacitor
- Required Size of Capacitor Bank
And the protection of capacitor bank
- Size of Main Fuse of Capacitor Bank
- Size of Circuit Breaker (Nr. This Value)
- Thermal Setting of Circuit Breaker
- Magnetic Setting of Circuit Breaker
- Size of Cable For Capacitor Connection
- Discharge Resistor for Capacitor
Capacitance Discharge Calculator Equations and a calculator for determining capacitance discharge rate of a capacitor
Capacitor Color Codes for Identification Capacitors may be marked with 4 or more colored bands or dots.
Capacitance Equations - Formulae Electrical Capacitance equations for various configurations.
Ceramic Capacitors Review Ceramic capacitors are part of the family of electrostatic capacitors.
Power Resistors - Review Power Resistors are resistors which are capable of handling a lot of power, as their name implies
HRC Fuse Design & Manufacturing RC fuse link is a very common, simple and effective electrical protection device
Tantalum Capacitors Review Tantalum capacitor is comprised of a permeable tantalum center section surrounded by tantalum pentoxide.
Power Transformer Power transformers are sometimes considered to be those with ratings of 300 volt-amperes and below.
Instrument Potential Transformer Instrument potential transformer (PT) steps down voltage of a circuit to a low value
Isolation Transformer Low power transformers used to isolate noise from or to ground electronic circuits.
Inverting Op-Amp Gain Table Calculator Excel Spreadsheet Premium Membership Required
Linear Circuit Source Calculator Excel Spreadsheet Premium Membership Required
Linear Applications Handbook , 1287 pages Premium Membership Minimum Required
Low - Voltage Circuit Breaker Low - voltage circuit breaker is one which is suited for circuits rated at 600 volts or lower
