Voltage Divider for 5% Resistors Calculator Excel Spreadsheet
NOTE:
Download:
Description: Divider for 5% Resistors Calculator Excel Spreadsheet
This sheet shows the outputs of a voltage divider for standard 5% valued resistors. Vin (currently set at 10V) can be changed to any desired input voltage and the sheet recalculated. Read the values of R1 down the left hand column, and the values of R2 across the top row.
