Fluid Control Valve Size Excel Spreadsheet Calculator
NOTE:
One and Two Phase Control Valve Sizing Macro Enabled Excel Spreadsheet Calculator
Download: One and Two Phase Control Valve Sizing Macro Enabled Excel Spreadsheet Calculator
This program provides calculation for the flow coefficient of compressible and incompressible fluids (single and two phase) through control valves.
Flow Equations for Sizing Control VaLVES, ansi/isa-75.01.01 2002/2012
Ajay S. Satpute
M. Tech (Chemical)
Indian Institute of Technology
