Pressurized Gas Blowout Time Excel Spreadsheet Calculator
NOTE:
Pressurized Gas Blowout Time Pipeline Excel Spreadsheet Calculator
Mass Flow Rate for Gas Pipeline Blowdown through Hole or Orifice Excel Spreadsheet Calculator
Download: Pressurized Gas Blowout Time Pipeline
Blow down down (or depressurization time) for a long distance natural gas pipeline. The depressuring or blowdown is assumed to be adiabatic and the heat exchange with the environment is neglected.
"Simple Method Predicts Gas Line Blowdown Times", by
M.H. Weiss, K.K. Botros, W.M. Jungowski, Oil & Gas Journal, Dec. 12, 1988
Excel Calculator Credit:
Ankur Srivastava
Chemical Engineer
