Pump Power Requirements Spreadsheet Calculator
NOTE:
Fluid Flow Design and Engineering
Requires a Premium Membership to download
Preview: Pump Power Requirements Spreadsheet Calculator
Download: Pump Power Requirements Spreadsheet Calculator
How the Worksheet Works
This spreadsheet allows the user to find the pump power requirement (Watts or Brake Horse Power) for various feeder pipe diameters (in) and given a known flow rate (LPS), pipe length (m) and head (m) and then select a suitable pump based upon available pump characteristic data.
Inputs:
  • Pipe length (m)
  • Difference in height between collector tank and reservoir (m)
  • Pump eff iciency (%)
  • Pipe size (m, in)
Outputs:
  • Pump flow required GPM, LPS
  • Fluid velocity
