Vapor Pressure Spreadsheet
NOTE:
Fluid Flow Design and Engineering
Vapor Pressure Spreadsheet Calculator
This worksheet approximates liquid vapor pressures for control valve sizing purposes. It is distributed at no charge on an as-is basis. The calculation uses the Antoine equation along with Antoine parameters as presented in the "NIST Chemistry WebBook".
Download:
Preview
