Water Hammer Accumulator Sizing Excel Spreadsheet Calculator
NOTE:
Water Hammer Pressure Water Hammer System Sizing Excel Spreadsheet Calculator
Download: Water Hammer Pressure Water Hammer System Sizing Excel Spreadsheet Calculator
Calculation of Actual Contaminated Firewater Volume
Simple method for sizing of an air vessel for surge or water hammer attenuation in long-distance pumped liquid pipelines. Surge or Water hammer can cause mechanical damage or rupture of pipelines. This may lead to serious consequences of release of pipeline contents to the surroundings due to rupture causing environmental and health hazards. Air vessels provide one of the simplest methods for protecting pipelines from damging water hammer effects. The refernce for the calculation method is provided in the excel workbook.
Ankur Srivastava
Simple Guide for Design of Air Vessels for Water Hammer Protection of Pumping Lines
