Related Resources: HVAC Heating Ventilation Air Conditioning
HVAC Air Handling Unit Design Excel Calculator
NOTE:
Description:
The Air Handling Unit Design Excel Calculator uses parameters such as sensible load, latent load, and total load to provide the remaining variables needed to select and specify air handling units. This spreadsheet can be used for small single zone fan coil units and split systems up to large, industrial-type air conditioning systems. The worksheet also has a section for estimating internal, external, and total static pressure so that fan selections can also be performed.
Preview: HVAC Air Handling Unit Design Excel Calculator
