Related Resources: fluid flow
Allowable Working Pressure Carbon Steel and High Yield Strength Pipe
Carbon Steel and High Yield Strength Pipe (Values apply to A106, API 5LX pipe having the same specified minimum yield strength as shown) |
Nom Pipe Size |
O.D.
Wall
Thk. |
Allowable Working
Pressures up to 250⁰F, in psig
Construction
type Design Factors
Type
A. F = 0.72"
Type B. F = 0.60
GR.B
GR.B
35,000
42,000
46,000
52,000
60,000
35,000
42,000
46,000
52,000
60,000
2
(STD) 2.375 |
.154
3268
2723
.218
4626
3855
3
3.500 (STD) |
.125
1800
1500
.156
2246
1872
.188
2707
2256
.216
3110
2592
.250
3600
3000
.281
4046
3372
.300
4320
3600
4
4.500 (STD) |
.125
1400
1680
1840
1167
1400
1533
.156
1747
2097
2296
1456
1747
1913
.188
2105
2526
2767
1754
2105
2306
.219
2453
2943
3223
2044
2453
2686
.237
2654
3185
3488
2212
2654
2907
.250
2800
3360
3680
2333
2800
3067
.281
3147
3776
4136
2623
3147
3447
.312
3494
4193
4593
2912
3494
3827
.337
3774
4530
4961
3145
3775
4134
6
6.625 (STD) |
.156
1187
1424
1560
1763
989
1187
1300
1469
.188
1429
1716
1880
2124
1192
1430
1567
1770
.219
1666
2000
2190
2475
1388
1666
1825
2063
.250
1902
2282
2500
2826
1585
1902
2083
2355
.280
2130
2556
2799
3164
1775
2130
2333
2637
.312
2373
2848
3120
3527
1978
2374
2600
2933
.375
2853
3424
3750
4237
2377
2853
3125
3531
.132
3287
3943
4319
4883
2739
3286
3599
4069
8
8.625 (STD) |
.156
912
1094
1198
1354
760
912
998
1128
.188
1098
1318
1444
1632
915
1098
1203
1360
.203
1186
1424
1559
1762
989
1186
1299
1469
.219
1280
1535
1681
1901
1067
1280
1401
1584
.250
1461
1753
1920
2170
1217
1461
1600
1809
.277
1618
1942
2128
2405
1349
1618
1773
2004
.312
1823
2189
2398
2709
1520
1823
1997
2258
.322
1882
2258
2473
2796
1568
1882
2061
2329
.344
2011
2412
2642
2988
1676
2011
2202
2490
.375
2191
2628
2880
3256
1826
2191
2399
2713
.438
2560
3071
3364
3803
2133
2560
2804
3170
.500
2922
3506
3840
4341
2435
2922
3200
3617
10
10.750 (STD) |
.188
881
1058
1158
1310
733
881
965
1091
.203
959
1143
1251
1415
794
952
1043
1179
.219
1026
1231
1348
1525
855
1026
1124
1271
.250
1172
1407
1540
1741
977
1172
1284
1451
.279
1309
1570
1719
1944
1091
1309
1433
1620
.307
1440
1728
1892
2138
1200
1440
1577
1782
.344
1613
1935
2120
2396
1344
1613
1767
1997
.365
1711
2054
2249
2542
1426
1711
1874
2119
.438
2054
2464
2700
3051
1712
2054
2250
2543
.500
2344
2813
3081
3483
1953
2344
2567
2902
12
12.750 (STD) |
.188
743
892
977
1104
619
743
814
920
.203
803
963
1055
1193
669
803
879
995
.219
866
1039
1138
1287
722
866
948
1073
.250
988
1186
1299
1468
824
988
1082
1224
.281
1111
1332
1460
1651
926
1111
1217
1376
.312
1233
1480
1620
1832
1028
1233
1350
1527
.330
1305
1566
1715
1939
1088
1305
1430
1616
.344
1359
1631
1786
2020
1133
1359
1488
1683
.375
1482
1779
1948
2202
1235
1482
1624
1835
.406
1606
1926
2110
2385
1338
1606
1758
1988
.438
1732
2077
2275
2572
1443
1732
1896
2144
.500
1976
2372
2598
2936
1647
1976
2165
2447
Type A construction also applicable to "Liquid Petroleum
Transportation Piping Code." ANSI B31.4-1979 |
Nom Pipe Size |
O.D. |
Wall Thk. |
Allowable Working Pressures up to 250⁰F, in psig |
Construction type Design Factors |
Type C. F = 0.50 |
Type D.F = 0.40 |
GR.B |
GR.B |
35,000 |
42,000 |
46,000 |
52,000 |
60,000 |
35,000 |
42,000 |
46,000 |
52,000 |
60,000 |
2 |
(STD) 2.375 |
.154 |
2270 |
1816 |
.218 |
3213 |
2570 |
3 |
3.500 (STD) |
.125 |
1250 |
1000 |
.156 |
1560 |
1248 |
.188 |
1880 |
1504 |
.216 |
2160 |
1728 |
.250 |
2500 |
2000 |
.281 |
2810 |
2248 |
.300 |
3000 |
2400 |
4 |
4.500 (STD) |
.125 |
973 |
1167 |
1278 |
778 |
933 |
1022 |
.156 |
1214 |
1456 |
1595 |
971 |
1165 |
1276 |
.188 |
1462 |
1755 |
1922 |
1170 |
1404 |
1537 |
.219 |
1704 |
2044 |
2239 |
1363 |
1635 |
1791 |
.237 |
1844 |
2212 |
2423 |
1475 |
1770 |
1938 |
.250 |
1945 |
2333 |
2556 |
1556 |
1869 |
2044 |
.281 |
2186 |
2622 |
2873 |
1748 |
2098 |
2298 |
.312 |
2427 |
2912 |
3190 |
1941 |
2330 |
2552 |
.337 |
2621 |
3146 |
3445 |
2097 |
2516 |
2756 |
6 |
6.625 (STD) |
.156 |
824 |
989 |
1083 |
1224 |
659 |
791 |
866 |
980 |
.188 |
993 |
1192 |
1306 |
1475 |
794 |
954 |
1044 |
1180 |
.219 |
1157 |
1389 |
1521 |
1719 |
926 |
1111 |
1216 |
1375 |
.250 |
1321 |
1585 |
1736 |
1963 |
1057 |
1268 |
1389 |
1570 |
.280 |
1479 |
1775 |
1944 |
2198 |
1183 |
1420 |
1555 |
1758 |
.312 |
1649 |
1978 |
2167 |
2449 |
1319 |
1582 |
1733 |
1959 |
.375 |
1981 |
2378 |
2604 |
2943 |
1585 |
1902 |
2083 |
2354 |
.132 |
2283 |
2738 |
3000 |
3391 |
1826 |
2191 |
2400 |
2713 |
8 |
8.625 (STD) |
.156 |
633 |
760 |
832 |
940 |
506 |
608 |
666 |
752 |
.188 |
763 |
915 |
1003 |
1133 |
610 |
732 |
802 |
907 |
.203 |
824 |
989 |
1083 |
1224 |
659 |
791 |
866 |
979 |
.219 |
889 |
1067 |
1168 |
1320 |
711 |
853 |
934 |
1056 |
.250 |
1014 |
1217 |
1333 |
1507 |
812 |
974 |
1067 |
1206 |
.277 |
1124 |
1349 |
1478 |
1670 |
899 |
1079 |
1182 |
1336 |
.312 |
1266 |
1520 |
1664 |
1881 |
1013 |
1216 |
1331 |
1505 |
.322 |
1307 |
1568 |
1717 |
1941 |
1045 |
1254 |
1374 |
1553 |
.344 |
1396 |
1676 |
1835 |
2075 |
1117 |
1340 |
1468 |
1660 |
.375 |
1521 |
1826 |
1999 |
2261 |
1217 |
1460 |
1599 |
1808 |
.438 |
1778 |
2133 |
2336 |
2641 |
1422 |
1706 |
1869 |
2113 |
.500 |
2029 |
2435 |
2667 |
3014 |
1623 |
1948 |
2133 |
2412 |
10 |
10.750 (STD) |
.188 |
612 |
735 |
804 |
909 |
490 |
588 |
644 |
728 |
.203 |
661 |
794 |
869 |
983 |
529 |
635 |
695 |
786 |
.219 |
713 |
855 |
936 |
1059 |
570 |
684 |
749 |
847 |
.250 |
814 |
977 |
1070 |
1209 |
651 |
781 |
856 |
967 |
.279 |
909 |
1091 |
1194 |
1350 |
727 |
872 |
955 |
1080 |
.307 |
1000 |
1200 |
1314 |
1486 |
800 |
960 |
1051 |
1189 |
.344 |
1120 |
1344 |
1473 |
1664 |
896 |
1075 |
1178 |
1331 |
.365 |
1188 |
1426 |
1562 |
1766 |
951 |
1141 |
1249 |
1412 |
.438 |
1426 |
1712 |
1875 |
2119 |
1141 |
1369 |
1500 |
1695 |
.500 |
1628 |
1953 |
2140 |
2419 |
1302 |
1563 |
1712 |
1935 |
12 |
12.750 (STD) |
.188 |
516 |
619 |
678 |
767 |
413 |
495 |
543 |
613 |
.203 |
558 |
669 |
733 |
829 |
446 |
535 |
586 |
663 |
.219 |
601 |
722 |
790 |
894 |
481 |
577 |
632 |
715 |
.250 |
686 |
824 |
902 |
1020 |
549 |
659 |
722 |
816 |
.281 |
771 |
926 |
1014 |
1146 |
617 |
740 |
811 |
917 |
.312 |
856 |
1028 |
1125 |
1273 |
685 |
822 |
900 |
1018 |
.330 |
906 |
1088 |
1191 |
1346 |
725 |
870 |
953 |
1077 |
.344 |
944 |
1133 |
1240 |
1403 |
755 |
906 |
992 |
1122 |
.375 |
1029 |
1235 |
1353 |
1529 |
824 |
988 |
1082 |
1224 |
.406 |
1115 |
1338 |
1465 |
1656 |
892 |
1070 |
1172 |
1325 |
.438 |
1203 |
1443 |
1580 |
1786 |
962 |
1154 |
1264 |
1429 |
.500 |
1373 |
1647 |
1804 |
2039 |
1098 |
1318 |
1443 |
1631 |
Type A construction also applicable to "Liquid Petroleum Transportation Piping Code." ANSI B31.4-1979 |
FIG. 17-27 (GPSA BOOK)
Gas Transmission and Distribution Piping
Code for Pressure Piping ANSI B31.8-1982
