API Casing Data Tables Size 10.750
API Casing Data Tables Size 10.750.
Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter ("OD"). This and related API documents also promulgate standards for the threaded end finish, the wall thickness (several are available in each size to satisfy various design parameters, and in fact are indirectly specified by standardized nominal weights per linear foot; thicker pipe obviously being heavier), and the strength and certain chemical characteristics of the steel material. Several material strengths: termed "Grades" and ranging from 40,000 pounds per square inch (276 MPa) to 150,000 pounds per square inch (1,034 MPa) minimum yield strength—are available for most combinations of OD and wall thickness to meet various design needs.
O.D.
(inch)
Nominal
Weight
T & C
Grade
Collapse
Pressure
(psi)
Internal Yield Pressure
Minimum Yield (psi)
Joint Strength
1000 lbs
PE
STC
LTC
BTC
STC
LTC
BTC
10.750
45.50
K-55
2090
3580
3580
3580
528
931
10.750
45.50
HCK-55
3130
3580
3580
3580
659
1037
10.750
45.50
LS-65
2280
4230
4230
4230
576
916
10.750
45.50
N-80
2470
5210
5210
5210
701
1097
10.750
45.50
HCN-80
3130
5210
5210
5210
799
1175
10.750
51.00
J-55
2700
4030
4030
4030
565
891
10.750
51.00
K-55
2700
4030
4030
4030
606
1043
10.750
51.00
HCK-55
4420
4030
4030
4030
756
1160
10.750
51.00
LS-65
2870
4760
4760
4760
661
1026
10.750
51.00
L-80
3220
5860
5860
5860
794
1190
10.750
51.00
HCL-80
4460
5860
5860
5860
906
1316
10.750
51.00
N-80
3220
5860
5860
5860
804
1228
10.750
51.00
HCN-80
4460
5860
5860
5860
916
1316
10.750
51.00
C-90
3400
6590
6590
6590
879
1287
10.750
51.00
H2S-90
4460
6590
6590
6590
916
1316
10.750
51.00
S-95
4460
6960
6960
6960
937
1392
10.750
51.00
T-95
3480
6960
6960
6960
927
1354
10.750
51.00
H2S-95
4460
6960
6960
6960
927
1354
10.750
51.00
C-95
3480
6960
6960
6960
927
1354
10.750
51.00
HCP-110
4460
8060
8060
8060
1080
1594
10.750
51.00
P-110
3660
8060
8060
8060
1080
1594
10.750
51.00
HCQ-125
4660
9160
9160
9160
1213
1758
10.750
51.00
Q-125
3740
9160
9160
9160
1213
1758
10.750
51.00
LS-140
4460
10260
10260
10260
1356
1959
10.750
55.50
HCK-55
5220
4430
4430
4430
843
1271
10.750
55.50
LS-65
3690
5240
5240
5240
736
1124
10.750
55.50
L-80
4020
6450
6450
6450
884
1303
10.750
55.50
HCL-80
5950
6450
6450
6450
1010
1441
10.750
55.50
N-80
4020
6450
6450
6450
895
1345
10.750
55.50
HCN-80
5950
6450
6450
6450
1021
1441
10.750
55.50
C-90
4160
7250
7250
7250
979
1409
10.750
55.50
H2S-90
5950
7250
7250
7250
1021
1441
10.750
55.50
S-95
5950
7660
7660
7660
1043
1524
10.750
55.50
T-95
4290
7660
7660
7660
1032
1483
10.750
55.50
H2S-95
5950
7660
7660
7660
1032
1483
10.750
55.50
C-95
4290
7660
7660
7660
1032
1483
10.750
55.50
HCP-110
5950
8860
8860
8860
1203
1745
10.750
55.50
P-110
4610
8860
8860
8860
1203
1745
10.750
55.50
HCQ-125
5950
10070
10070
10070
1351
1925
10.750
55.50
Q-125
4850
10070
10070
10070
1351
1925
10.750
55.50
LS-140
5950
11280
11280
11280
1510
2146
10.750
60.70
L-80
5160
7100
7100
7100
983
1428
10.750
60.70
HCL-80
7550
7100
7100
7100
1123
1579
10.750
60.70
N-80
5160
7100
7100
7100
996
1473
10.750
60.70
N-80
5160
7100
7100
7100
996
1473
10.750
60.70
HCN-80
7550
7100
7100
7100
1136
1579
10.750
60.70
C-90
5460
7980
7980
7980
1089
1544
10.750
60.70
H2S-90
7550
7980
7980
7980
1136
1579
10.750
60.70
S-95
7550
8430
8430
8430
1161
1670
10.750
60.70
T-95
5590
8430
8430
8430
1148
1625
10.750
60.70
H2S-95
7550
8430
8430
8430
1148
1625
10.750
60.70
C-95
5590
8430
8430
8430
1148
1625
10.750
60.70
HCP-110
7550
9760
9760
9760
1338
1912
10.750
60.70
P-110
5880
9760
9760
9760
1338
1912
10.750
60.70
HCQ-125
7550
11090
11090
11090
1503
2109
10.750
60.70
Q-125
6070
11090
11090
11090
1503
2109
10.750
60.70
LS-140
7550
12420
12420
12420
1680
2351
O.D.
(inch)
Nominal
Weight
T & C
Grade
Collapse
Pressure
(psi)
Body Yield
1000 lbs
Wall
(inch)
I.D.
(inch)
Drift Diameter
(inch)
API
LSS
10.750
45.50
K-55
2090
715
0.400
9.950
9.794
9.875
10.750
45.50
HCK-55
3130
715
0.400
9.950
9.794
9.875
10.750
45.50
LS-65
2280
845
0.400
9.950
9.794
9.875
10.750
45.50
N-80
2470
1040
0.400
9.950
9.794
9.875
10.750
45.50
HCN-80
3130
1040
0.400
9.950
9.794
9.875
10.750
51.00
J-55
2700
801
0.450
9.850
9.694
10.750
51.00
K-55
2700
801
0.450
9.850
9.694
10.750
51.00
HCK-55
4420
801
0.450
9.850
9.694
10.750
51.00
LS-65
2870
946
0.450
9.850
9.694
10.750
51.00
L-80
3220
1165
0.450
9.850
9.694
10.750
51.00
HCL-80
4460
1165
0.450
9.850
9.694
10.750
51.00
N-80
3220
1165
0.450
9.850
9.694
10.750
51.00
HCN-80
4460
1165
0.450
9.850
9.694
10.750
51.00
C-90
3400
1311
0.450
9.850
9.694
10.750
51.00
H2S-90
4460
1311
0.450
9.850
9.694
10.750
51.00
S-95
4460
1383
0.450
9.850
9.694
10.750
51.00
T-95
3480
1383
0.450
9.850
9.694
10.750
51.00
H2S-95
4460
1383
0.450
9.850
9.694
10.750
51.00
C-95
3480
1383
0.450
9.850
9.694
10.750
51.00
HCP-110
4460
1602
0.450
9.850
9.694
10.750
51.00
P-110
3660
1602
0.450
9.850
9.694
10.750
51.00
HCQ-125
4660
1820
0.450
9.850
9.694
10.750
51.00
Q-125
3740
1820
0.450
9.850
9.694
10.750
51.00
LS-140
4460
2039
0.450
9.850
9.694
10.750
55.50
HCK-55
5220
877
0.495
9.760
9.604
9.625
10.750
55.50
LS-65
3690
877
0.495
9.760
9.604
9.625
10.750
55.50
L-80
4020
1276
0.495
9.760
9.604
9.625
10.750
55.50
HCL-80
5950
1276
0.495
9.760
9.604
9.625
10.750
55.50
N-80
4020
1276
0.495
9.760
9.604
9.625
10.750
55.50
HCN-80
5950
1276
0.495
9.760
9.604
9.625
10.750
55.50
C-90
4160
1435
0.495
9.760
9.604
9.625
10.750
55.50
H2S-90
5950
1435
0.495
9.760
9.604
9.625
10.750
55.50
S-95
5950
1515
0.495
9.760
9.604
9.625
10.750
55.50
T-95
4290
1515
0.495
9.760
9.604
10.750
55.50
H2S-95
5950
1515
0.495
9.760
9.604
9.625
10.750
55.50
C-95
4290
1515
0.495
9.760
9.604
9.625
10.750
55.50
HCP-110
5950
1754
0.495
9.760
9.604
9.625
10.750
55.50
P-110
4610
1754
0.495
9.760
9.604
9.625
10.750
55.50
HCQ-125
5950
1993
0.495
9.760
9.604
9.625
10.750
55.50
Q-125
4850
1993
0.495
9.760
9.604
9.625
10.750
55.50
LS-140
5950
2233
0.495
9.760
9.604
9.625
10.750
60.70
L-80
5160
1398
0.545
9.660
9.504
10.750
60.70
HCL-80
7550
1398
0.545
9.660
9.504
10.750
60.70
N-80
5160
1398
0.545
9.660
9.504
10.750
60.70
N-80
5160
1398
0.545
9.660
9.504
10.750
60.70
HCN-80
7550
1398
0.545
9.660
9.504
10.750
60.70
C-90
5460
1573
0.545
9.660
9.504
10.750
60.70
H2S-90
7550
1573
0.545
9.660
9.504
10.750
60.70
S-95
7550
1660
0.545
9.660
9.504
10.750
60.70
T-95
5590
1660
0.545
9.660
9.504
10.750
60.70
H2S-95
7550
1660
0.545
9.660
9.504
10.750
60.70
C-95
5590
1660
0.545
9.660
9.504
10.750
60.70
HCP-110
7550
1922
0.545
9.660
9.504
10.750
60.70
P-110
5880
1922
0.545
9.660
9.504
10.750
60.70
HCQ-125
7550
2184
0.545
9.660
9.504
10.750
60.70
Q-125
6070
2184
0.545
9.660
9.504
10.750
60.70
LS-140
7550
2446
0.545
