Related Resources: fluid flow
Convergent Nozzle Flow Velocity and Area Equation and Calculator
Hydraulic & Pneumatics
Nozzles are used in steam and gas turbines, in rocket motors, in jet engines and in many other applications. Two types of nozzle are considered: the ‘convergent nozzle’, where the flow is subsonic; and the ‘convergent divergent nozzle’, for supersonic flow.
Outlet pressure p2 greater than pc, i.e. r > rc
Convergnet Nozzle Equation and Calculator
Nozzle Outlet Velocity Equation
Nozzle Critical Pressure Ratio:
Nozzle Outlet Area Equation
When Outlet pressure p2 equal to or less than pc, i.e. r ≤ rc the following equation applies;
Note that C2 is independent of p2 and that the nozzle flow is a maximum. In this case the nozzle is said to be ‘choked’.
where:
p1 = Inlet pressure (N / m2, Pa)
p2 = Outlet pressure (N / m2, Pa)
pc = critical pressure at throat (N / m2, Pa)
v1 = Inlet specific volume (m3)
vc = Outlet specific volume (m3)
C2 = Outlet velocity (m/sec)
Cc = Throat velocity (m/sec)
r = pressure ratio = p1 / p2
rc = critical pressure ratio
A2 = outlet area (m2)
Ac = throat area (m2)
n = index of expansion
m = mass flow rate (kg/m2)
Fluid
n
rc
Air (n = γ)
1.40
0.528
Initially dry saturated steam
1.135
0.577
Initially superheated steam
1.30
0.546
